I am not using expression.
I set Cp(specific heat) to piecewise-polynomial.
Also inlet and out temperature are the same (303K)
I also set same temperature value as the operating temperature
The thermal condition on the wall is "Heat Flux" for all the wall below
Please Login to Report Topic
Please Login to Share Feed
Edit Discussion
You are navigating away from the AIS Discovery experience
