Ansys Learning Forum Forums Discuss Simulation Fluids Error report in multiphase flow simulation Reply To: Error report in multiphase flow simulation
i.tamunodienye2
I did not patch the flow. The flow is completely filled with liquid at initialization. The mesh was ok with just VOF and also ok when i initialized with gas(but in reverse flow). I try use other meshes and try. This is how the hybrid-initialization comes up
I varied the solution control several times but this did not go away.
