Ansys Learning Forum Forums Discuss Simulation Fluids A problem for dynamic adapt mesh Reply To: A problem for dynamic adapt mesh
OK, that doesn't retain any adaption data so can mean you get additional adaption over not pausing the run. The newer h5 (HDF) format retains registers and adaption levels so should avoid this issue.
