Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Error inside ANSYS LS Dyna: “An error occurred inside the SOLVER module: general error.” › Reply To: Error inside ANSYS LS Dyna: “An error occurred inside the SOLVER module: general error.”
October 26, 2021 at 11:13 pm
Hi Erik,
I did post but I was waiting for the 2021 R2 version to be installed. I designed a cube and input a force with a fixed support on the bottom of the cube. It is showing the same error as before.
Here are the pictures of what I found for this simple simulation:
Regarding the solution information, there is no text there, here is the image:
I am sending the file of the simulation attached.
Thank you very much Leonardo Wei
