Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Modelling Electrical Contact Resistance › Reply To: Modelling Electrical Contact Resistance
October 27, 2021 at 6:10 pm
The joule heat you specified should not prevent you from specifying a thermal contact conductance for contact elements between the two surfaces. The thermal conductance specified for the contact elements will produce the heat produced by the ohmic resistance of the contact.
