Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Importing external data in cylindrical coordinate to mechanical thermal mesh › Reply To: Importing external data in cylindrical coordinate to mechanical thermal mesh
October 28, 2021 at 2:45 am
Hi Aniket
Thanks for your reply, and I want to consult you that I intend to load three different external data (heat generate rate) vs. time, indicating three different heat loads in three different positions vs. time. I want to do such a periodic heat cycle among the three heat loads until the temperature to the steady state.
I have no idea if there is a convenient method to do such a transient calculation so that I don't need tofill from "0:heat generation1" to "2:heat generation1" in the below blank again and again. Thanks in advance.
