Ansys Learning Forum › Forums › Discuss Simulation › Fluids › nanofluid is flowing inside the tube shown in fig below & air is flowing over fins through enclosure › Reply To: nanofluid is flowing inside the tube shown in fig below & air is flowing over fins through enclosure
OK, so you need to rethink the geometry so that the two streams can't mix. You also need to find where the highly skewed cells are and sort those out: 0.99999 skew is essentially flat, and will cause the solver to fail.
