Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Spherical contact on elastic half space › Reply To: Spherical contact on elastic half space
October 12, 2021 at 11:15 am
A Hertzian contact problem is a a nonlinear contact model so you need to model the contact in detail in order to capture the pressure distribution. Since Hertz Stress is highly localized, you don't need to model a complete sphere, a half sphere will do. Depending on your problem, you may need to turn on Large Deflection Setting.
You can google "HERTZIAN CONTACT STRESS CALCULATOR" for common contact configurations.
For detailed explanation of Penetrating Contacts , please refer to these links:
Interpreting Contact Penetration - YouTube
VM191 (ansys.com)
Thank you,
Vinayak.
VM191 (ansys.com)
Thank you,
Vinayak.
