Ansys Learning Forum Forums Discuss Simulation 3D Design conversion from stl format to solid Reply To: conversion from stl format to solid
peteroznewman
Link to Google Search results for converting stl to solid.
Here is your STL file:
I recommend you slice a unit cell and work on converting just that to a solid, then use a pattern to fill out the larger solid.
