Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Regarding pre filling a geometry before multiphase vof simulation › Reply To: Regarding pre filling a geometry before multiphase vof simulation
November 1, 2021 at 5:16 pm
Calculate the momentum of the injection. Then calculate the Stokes relaxation time and terminal velocity.
At 0.1 micron and 0.01mm/s the particle isn't going to go anywhere other than by Brownian motion, diffusion or numerical errors: ie you won't see it move unless the fluid is also moving.
