Ansys Learning Forum Forums Discuss Simulation General Mechanical Nonlinear static analysis with failure initiation and evolution Reply To: Nonlinear static analysis with failure initiation and evolution
peteroznewman
If the materials are in the linear elastic range with a first value of displacement d, and you double that to a value of 2d, which is still in the linear elastic range, then the stress and the strain should double.
