Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to select an internal node within a body? › Reply To: How to select an internal node within a body?
September 22, 2021 at 11:10 am
Thanks you both very much for your answers.
I had avoided inserting a cut face as it was causing problems with my multizone hex mesh generation, and i did not want to apply the changes to a single bolt to resolve them. In any case if i have to do this after i have tried the other options i will have no choice.
Again the prompt response is much appreciated.
Cheers Michael
Cheers Michael
