Ansys Learning Forum Forums Discuss Simulation General Mechanical Changing RVEs size in Material Designer Reply To: Changing RVEs size in Material Designer
sadiqamin475550
Another issue I am facing is wether I can consider a multi-layered chopped strand mat-resin composite as isotropic in 3d? because fibres in chopped strand mat are distributed only in a plane.
So I have also calculated values of this composite considering it as isotropic as per Agarwal composite book.
I have attached a screentshot.
