Ansys Learning Forum Forums Discuss Simulation LS Dyna How to output the nodal history stress Reply To: How to output the nodal history stress
longt8
Hello tslvik I know *DATABASE_ELOUT and *DATABASE_HISTORY_SOLID or *DATABASE_HISTORY_SOLID_SET should be used at the same time. <- combination 1
The combination 1 is to output the element stress rather than nodal stress, is there any way to output the nodal stress? the nodal value is my goal,
I also know *DATABASE_NODOUT and *DATABASE_HISTORY_NODE or *DATABASE_HISTORY_NODE_SET also should be used at the same time. <- combination 2
- combination 2 seems can output nodal stress, but option can not be found by combination 2:
Could you give me the suggestion to output the nodal stress directly?
Thank you!
Best Teng
