Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Core depth › Reply To: Core depth
Navya Chode
Hi @smks1991 As far as I know, the BH data and core loss data you are defining are as per the thickness of the lamination and this data will vary with the lam thickness even the material is the same.
lamination thickness is taken care of when you input this data in material definition. It is enough if you define the composition as lamination and stacking factor in the material definition window.
So, if you are choosing a material from the material library say, M19-29G it means the lamination thickness is 0.36mm. Similarly 0.47mm and 0.64 mm for 26 and 24 gauge respectively. But the loss data and corresponding loss coefficients will vary for each.
Regards Navya
