Ansys Learning Forum Forums Discuss Simulation General Mechanical Does non-linear analysis in ANSYS also make use of direct solvers or not? Reply To: Does non-linear analysis in ANSYS also make use of direct solvers or not?
Rameez_ul_Haq
,and what would you say about this one?
"the nodes closer to the center might have higher share of force transfer and thus might have higher deformations then the rest of the nodes, which are far away from the center?"
