Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › How to perform two step dynamic analysis in Ansys Mechanical › Reply To: How to perform two step dynamic analysis in Ansys Mechanical
peteroznewman
You have two joints holding onto the same blue edge on the frame. Use a single joint to hold all 4 edges. Delete all duplicates and repair remaining joints to eliminate this condition.
Below is the repaired joint with the duplicate suppressed.
