Ansys Learning Forum Forums Discuss Simulation Fluids DO-model makes simulation diverging Reply To: DO-model makes simulation diverging
Yannice
Hi Rob Thank you for your suggestion, however it is not solved yet.
If the do-intensity under relaxation is higher than 0.5, it can be clearly seen that do-intensity residuals diverge first (but: no sunshine yet at that moment!)
What is the maximum cell size recommended when using the DO radiation model (and/or the Solar Load Model)?
Best regards
