Ansys Learning Forum Forums Discuss Simulation Fluids Complex dynamic of fluent in FSI Reply To: Complex dynamic of fluent in FSI
Karthik Remella
Administrator
You will most likely need to use layering (if your mesh is structured) or remeshing (if it is an unstructured hex). I would prefer using an unstructured mesh since you are talking about an FSI simulation.
For all practical purposes, the dynamic meshing component, whether you are working on FSI or non-FSI, is pretty much the same (with some very minor differences). But since you bring this up, you could have a look at some of the tutorials outlined on Ansys Help under System Coupling. Here is the link.
System Coupling Tutorials (ansys.com)
You should be able to find the corresponding files as well here.
I hope this helps.
Karthik
