Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Circuit design parametric running to slow? › Reply To: Circuit design parametric running to slow?
July 29, 2021 at 2:20 pm
francisco_nunez
Runing bellow 2.5k parametric iterations get the results ok. The "computing variations" run instantly, then the "Analysis pregress" begin showing "solved= XX Solving XX Remining XX". This instance run very fast.
The problem resides in bigger iterations. I check the CPU % and MEM% and both are below 50% load (INTEL Core i5-7400 3.00 GHz (33%), 14.5/31.9 GB MEM(45%)). This is strange because in other soft like ADS no problems are show, no instantly do, but no the ridiculous 40hs+ and still runing, now in the "solving" instance. I like use only ANSYS for practical reason. I have a feeling that im doing something wrong. I need 50K iterations because fewer get bad results in the calibration process of the model.
Regards
Regards
