Ansys Learning Forum › Forums › Discuss Simulation › Fluids › What is the relationship between Solidification/Melting model and VOF model? › Reply To: What is the relationship between Solidification/Melting model and VOF model?
CFD_newbie
Thank you for your reply.
I am trying to simulate the PCM melting process. There are only solid and liquid PCM in a tank. The PCM material in the tank is heated from the solid phase to the liquid phase. Does the solidification/melting model need to be combined with the VOF model? Or is it enough to just use the solidification/melting model? When combining VOF or not, what is the difference between the results?
