Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Contact connection between multiple surfaces › Reply To: Contact connection between multiple surfaces
July 28, 2021 at 11:06 am
Saurabh1011
Thank you for the advice. I will do that multibody part thing to avoid interface zone in fluent. But by using the multi-body part, does it solve the problem of contact mapping between multiple surfaces? I mean do I have to create 1 to 1 contact mapping for each contact region or should I leave it to the automatic algorithm? (Where it makes 1 contact region with 3 surfaces of one body mapping to 3 surfaces of other body). I am going to do a more complex problem where there will be 90 contacts if I have to do 1 to 1 contact instead of multiple surface contact.
