Ansys Learning Forum Forums Discuss Simulation Fluids Fluent Meshing poly-hexcore Reply To: Fluent Meshing poly-hexcore
Rozpruwacz10000
Sorry for the trouble, I was in error. It turns out that you can set volume fill options if size field is not computed. If it is, fluent meshing uses it for the calculations of volumetric sidizings. My mistake.
Wojtek
