Ansys Learning Forum Forums Discuss Simulation Fluids Fluent Meshing poly-hexcore Reply To: Fluent Meshing poly-hexcore
Rozpruwacz10000
I'm using 2020R2 version of standalone Fluent Meshing (not in Workbench). I've only encountered this in hexcore options. When I follow this steps:
surface mesh -> compute volumetric regions -> auto mesh I get this behavior. If there is volume mesh generated and I delete it, and use auto mesh again I can change this parameter. I also encountered this behavior in 2019 releases.
