Ansys Learning Forum Forums Discuss Simulation General Mechanical Mass which is hung onto the dampers that is compressed by 1mm. Reply To: Mass which is hung onto the dampers that is compressed by 1mm.
Mohank23
Hi Erik can you provide the sample APDL code of the damper spring modal analysis .
Thanks Mohan
