Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Windkessel model – Reverse flow in Fluent 2020 › Reply To: Windkessel model – Reverse flow in Fluent 2020
July 26, 2021 at 12:08 pm
Hi Rob
Thank you for your reply. By geometry look like below.
At the inlet 1, applying mass flow inlet which is a periodic pulse.
At the inlet2, applying constant mass flow rate.
At all the outlets, applying pressure outlet condition (attached below)
I am observing the reverse flow at the outlet BCA, LSCA, LCCA (almost 100% reverse flow).
At the inlet 1, applying mass flow inlet which is a periodic pulse.At the inlet2, applying constant mass flow rate.
