Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to give viscosity and surface tension under material properties for a solid melting problem? › Reply To: How to give viscosity and surface tension under material properties for a solid melting problem?
July 26, 2021 at 11:17 am
You'll need a value for the "solid" part too, but you can set that as a low value.
