Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Temperature Vs pressure › Reply To: Temperature Vs pressure
July 26, 2021 at 2:19 pm
How much vapour did you add? Remember density is set in the materials panel, either at the species or mixture level. If you didn't change any defaults then you may not get the result you expect.
