Ansys Learning Forum Forums Discuss Simulation Fluids Is there any way to calculate F_AREA,NV_MAG manually? Reply To: Is there any way to calculate F_AREA,NV_MAG manually?
Karthik Remella
Administrator
Hello What do you mean by 'manually'? If it is a separate face zone, you should be able to use the 'surface integral' (area) option to estimate the total surface area. You should be able to compare the two values (from the UDF and Fluent post-processing) obtained. Is this what you are looking for?
Karthik
