Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Loosening of bolt under dynamic loading › Reply To: Loosening of bolt under dynamic loading
Soban
I want to perform the analysis with the following data Cyclic transverse vibrations were simulated based on quasistatic assumption and dynamic processes with the
vibration frequency of 10 Hz
time of vibration 5 sec
amplitude of vibration is 0.05mm
pretension in bolt is 10 KN
Link of paper is "https://journals.sagepub.com/doi/abs/10.1177/0954406217745337#:~:text=Finite%20element%20analysis%20has%20been,of%20bolted%20joints%20under%20vibration.&text=These%20influencing%20factors%20include%20preload,vibration%20parameter%2C%20and%20material%20model.
