Ansys Learning Forum Forums Discuss Simulation Fluids Air Injection Distance Simulation Reply To: Air Injection Distance Simulation
You may want to review mesh resolution: just because the cell quality is good it doesn't mean the mesh is. Compare the above with the result if you half the cell size. Then repeat for a further reduction in cell size.
To add, you may find some background reading on the Coanda Effect to be worthwhile.
