Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Software Execution error inside the mesher › Reply To: Software Execution error inside the mesher
July 28, 2021 at 12:24 pm
Thank you for your reply.
Yes. I tried Meshing step by step with all the parts. Then I found there was one bottom stiffener was in out of position 0,6 mm when I tried to mesh it. Then I add 1mm pinch to this part and meshed it. It got modified itself and mesh was successfull.
Thank you !
Thank you !
