Ansys Learning Forum Forums Discuss Simulation Preprocessing Knee joint – Problems with geometry Reply To: Knee joint – Problems with geometry
peteroznewman
Hello Jonas I have a video for converting STL to Geometry in this discussion: /forum/discussion/29718/convert-stl-of-knee-joint-to-geometry
ANSYS Mechanical has the ability to apply a Coating to a solid body. The coating automatically creates shell elements on the surface of the solid body that can have completely different properties to the material assigned to the solid. You type in the thickness of the coating. Have you looked at that capability?
