Ansys Learning Forum Forums Discuss Simulation Fluids Explicit VOF vs Implicit VOF for Laser Melting? Reply To: Explicit VOF vs Implicit VOF for Laser Melting?
Dubey92
Thanks a lot for your suggestion. My total time itself is small( = 1.6e-3s). I started with the above parameters and solution was converging but abruptly shows "floating point exception" after 21 % of completion.
I cannot understand why it shows "floating point exception" after one-fifth of the solution is done and the solution is converging also.
