Ansys Learning Forum › Forums › Discuss Simulation › Fluids › NUMERICAL ERRORS IN PCM MELTING › Reply To: NUMERICAL ERRORS IN PCM MELTING
If you have a look for Solver Limits you'll find a way to cap the temperature: use with caution and read up on what it actually does.
Re the solver stability, I assume the PCM material is constant density?
