Ansys Learning Forum Forums Discuss Simulation Fluids Need help in 6dof udf with a face loop Reply To: Need help in 6dof udf with a face loop
Surya Deb
It is not possible to check your entire UDF. But I think you might be missing commands to transfer from node to host after global summing.
Check this link for a parallel UDF example. [https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v212/en/flu_udf/flu_udf_sec_parallel_example.html?q=parallel]
Regards SD
