Ansys Learning Forum Forums Discuss Simulation General Mechanical why does ansys mechanical use the SSD instead of the RAM? Reply To: why does ansys mechanical use the SSD instead of the RAM?
rsasson
thanks for your reply.
tha command you recommend, where in the model tree should i put it?
if eventually the RAM requiered exceeds the available, does this command results in an error or will it run anyway using the SSD?
thanks again
