Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Tape Insert Meshing › Reply To: Tape Insert Meshing
July 27, 2021 at 1:49 pm
Try the following and see if it helps
Control the meshing sequence. Select one body, right click and select "generate mesh on selected body". Continue with the process for other bodies
Use a different method - Sweep or Multizone
If problem persists, you can use "preview surface mesh" when using sweep method. You will have to inspect the mesh and see if there are region with poor quality, in which case you will have adjust mesh sizes to improve the quality
