Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Automating from SpaceClaim to Fluent › Reply To: Automating from SpaceClaim to Fluent
rahul.kumar
I hope you are using Workbench for this. If you have used scripting in SC, create a driving dimension that can be called in the script and this will appear in the parameters tab in WB. And this way, you can change the driving dimension parameters / meshing parameters and run different design points.
