Ansys Learning Forum Forums Discuss Simulation General Mechanical Circle Pattern of beams Reply To: Circle Pattern of beams
erik.kostson
Not sure, but try. Aslo only align those beams that need it (so select only those)
Otherwise if it does not work ,select all the beams that need to be aligned, and use to rotate/orientation tool to rotate them 180 degrees or as needed.
All the best
Erik
