Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to make air flow from inlet into an object with holes › Reply To: How to make air flow from inlet into an object with holes
VigneshV18
Hi Rob I tried changing the inlet and outlet face on the outer domain, like the inlet is directly above the holes. in this case, i see that air flow is going into the enclosure. please have a look into the below screenshot.
And also please find the screenshot of velocity as contour on the symmetry plane.
My doubt is, does air only travel in a straight line when not disturbed?
