Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › LS Prepost to calculate J integral › Reply To: LS Prepost to calculate J integral
longt8
Hello jday Yes, do I have to use "ton, N, mm, s, MPa, N-mm" as my unit in order to calculate J-integral where unit is N-mm?
My unite is N, m, s, Pa, N-m, so I want to know the default unit setting for this.
Thank you!
Best Teng
