Ansys Learning Forum Forums Discuss Simulation Fluids Reverse flow in turbulent simulation Reply To: Reverse flow in turbulent simulation
Have a look at the flow field, colour contours by x-velocity and alter the scales to highlight positive x-velocity (clip is worth investigating). Also read up on jet entrainment.
Read the theory on the turbulence models: why are you using standard k-e?
