Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Time-Dependent Local Thermal Effects on Johnson-Cook Material Model › Reply To: Time-Dependent Local Thermal Effects on Johnson-Cook Material Model
Akshay Maniyar
Specific heat capacity must be defined to enable the calculation of temperature for thermal softening effects. You cab refer to the below link for more details about the Johnson cook strength model.
regards amaniyar
