Ansys Learning Forum Forums Discuss Simulation Platform Add Fluent Component in Twin Builder (Simplorer) Reply To: Add Fluent Component in Twin Builder (Simplorer)
LuisFig
Hello Karthik First of all thank you for your help.
At this point, in order to implement my co-simulation, in the Simplorer, the Fluent component has 1 input and 1 output terminals that are connected to the terminals of a resistor (by a wire).
I've already been able to connect the Fluent component terminals with the resistor through components called C2NC (conservative to Non-conservative), but I am not sure if this is right because when I analyze (run) the Simplorer, the following errors show up in the FLUENT:
This is the screenshot of how my elements are connected:
I would very much appreciate if somebody could help me. Thank you in advance.
