Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Bandstructure and dipole_cloud analysis group › Reply To: Bandstructure and dipole_cloud analysis group
anshuman.kumar
Hi Kjohnson Thank you for your response. I am facing a rather peculiar problem while running bandstructure and spr resonance simulations. When I run sweep over "K-points" for bandstructure or "theta" for resonance, my file is getting stuck at "wrapping up" stage (please refer to the screenshot attached).
To check if there is some problem with simulation file or with the software itself, I installed the trial version of the software on a different computer and the simulation seems to run fine on the trial version.
Could you please suggest what could possibly be causing this problem on the licensed version. FYI.. the computer has sufficient memory with 128GB RAM and dual processors; the lumerical software is also updated to the latest version.
Look forward to hear from you.
