Ansys Learning Forum Forums Discuss Simulation General Mechanical Create a Table with time, deformation amplitude and node location (length) Reply To: Create a Table with time, deformation amplitude and node location (length)
MCK_Pandaleon
Hello !
Thank's for the code lines.
Basically I am running harmonic responses and plotting the directional deformation along a set path. I have found that plotting length vs deformation when the path is defined with construction geometry is and automatic. However I would like to be able to access this plot for each time in the "deformation cycle", right now it plots deformation vs length at a random time and I can't figure out how to select it at a different time. (I believe we have access to this information with harmonic response because you can visualise a full cycle on ANSYS by playing the animation ).
I am not sure if this is a clear explanation.
The top row would be for the "time", the left column would stock the length (I'd actually need 34 rows ), and in the other rows you'd have the amplitude of the deformation at the corresponding length on the path depending on the time at which it is measured.
Do you understand what I mean?
