Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › What is the accurate way to create mesh around FSI boundary in Harmonic Acoustics? › Reply To: What is the accurate way to create mesh around FSI boundary in Harmonic Acoustics?
peteroznewman
Dear Parinaz Design Modeler has more steps to accomplish the same effect that you can do with very few clicks in SpaceClaim.
Use Face Split and a Plane twice.
To Share Topology, you must select both bodies in the Outline then right click and select Form New Part.
Now the Shared Topology should work to make a congruent mesh. However, when I tried to mesh, it did not go well. I went back to DM and instead of split face, I used Concept Slice and sliced up the disk and the liquid body with 4 slices to make 12 pieces of liquid and 4 pieces of disc. Also, the enclosure will mesh more easily if it is also a cylinder not a box.
One improvement is to add a radial bias.
