Ansys Learning Forum Forums Discuss Simulation Fluids Please help me… Setting up the filling layer Reply To: Please help me… Setting up the filling layer
ESL
Thank you for your reply.
In addition, I am sorry for the delay in replying.
In my simulation, I am studying the heat exchange between a reciprocating fluid flow and a porous medium in a channel with a porous medium of varying temperature.
Specifically, the porous medium represents a packed layer of spherical material.
In other words, we are simulating the temperature change when a fluid flows through a channel with a large amount of spherical materials that generate and absorb heat.
From here, I will reply to your questions.
Òâ╗Are all of them porous regions?
In the simulation, there are areas that are porous and areas that are not.
Does it show the outline of the cross-sectional view?
It is a cross-sectional view of the porous region and shows the temperature.
Òâ╗What does the variable "Temp_change" mean?
As mentioned above, the filling layer, which represents porosity, either exothermic or endothermic in a time-dependent manner. This contour diagram shows the temperature, specifically the temperature change of the packing layer per unit time step. The problem here is that the porosity of the fluid is 0.36, yet the area of the packed layer that would change in temperature is small.
These are my answers. I hope this helps you.
