Ansys Learning Forum Forums Discuss Simulation Preprocessing Kindly help me solve this error: Specified range 0 to 0 is not permitted. D command is ignored. Reply To: Kindly help me solve this error: Specified range 0 to 0 is not permitted. D command is ignored.
mrife
It would help if you posted the complete D command you are issuing. I'm guessing that the node field of the command has been accidentally set to be zero (0). Instead of an existing node number.
Mike
